Wooden Clock Plans from Clayton Boyer
Last modified: February 19, 2024
I've always loved these open framework wooden clocks. They seem like ideal CNC projects, especially if you are set up with a CNC router. Friends are constantly asking me what I make with all the machines in my shop and when I answer that I mostly make more tools, they're always disappointed or at least puzzled. One of these would be an ideal thing for a non-CNC person to relate to.
Check out some of Clayton Boyer's designs:
Wooden mechanical device with gears, levers, and other components on a light gray background.
This one is called "Space Time Continuum"...
Complex mechanical device with interlocking gears and levers made from light-colored wood or plastic.
"Celestial Mechanics" can track many astronomical events...
Close-up image of intricately designed wooden clockwork mechanism with interlocking gears.
"Simplicity" is the easiest design Boyer offers...
I haven't actually seen the drawings you can order, but the clocks sure look like great projects. The plans are not expensive-"Simplicity" lists for $37. If anyone reading has experience with Clayton's plans, drop us a note and let us know what you thought.
And, if you like gear work, be sure to also check out Georotic Gear Design Software.  It's great for designing projects like these.
