What is GD&T? [ CNCCookbook Beginner's Guide ]
Last modified: January 31, 2018
What is GD&T?  The answer is simple, Geometric Dimensioning and Tolerancing (GD&T) is a set of standardized symbols and conventions that are used to describe parts in a way that makes it easier for customers, manufacturers, and other supply chain participants to successfully communicate. Parts that are manufactured in a shop must meet specific specifications. These specifications are shown on engineering drawings, which are normally produced by CAD software. GD&T is a particular set of conventions used on engineering drawings (often called "prints" from the older "blueprints") that communicate how parts should fit together and how they function. This course will teach you the basics of how to understand GD&T symbols and their use.
GD&T is a standardized international system based on symbols that can be clearly understood by anyone that is familiar with the standard. It is a mathematical language, though it does not require you to be a math expert in order to understand and use the system. GD&T is a significant improvement over traditional older systems for describing dimensions that relate to the fit, form, and function of parts. It is very precise as well as concise relative to these older systems. Each work piece is described in terms of "zones of tolerance" that are relative to the Cartesian coordinate system. As you recall, Cartesian coordinates are just X, Y, and Z measurements from an origin. If you're a CNC'er, you're already quite familiar with them.
Simple geometric shape technical drawing with dimensions.
A simple drawing with GD&T symbols. Image Source
If GD&T seems complex, it is only because there is a long list of ways a physical part can deviate from the geometric ideal of what the designer had in mind. A shaft could be slightly bent, slightly tapered, slightly tilted, and slightly offset from where it was intended. When you consider all the different kinds of geometry found in machined parts, it's no wonder that cataloging all the defects in that geometry gets a bit complicated. GD&T actually brings some order to that complexity and makes it systematic.
History and Background of GD&T
GD&T is an international system because the American Society of Mechanical Engineering and the International Organization for Standardization worked together to create it. The actual written standards they produced are ASME Y14.5M and ISO 1101. While the standards are relatively recent, the ideas behind GD&T go back to the 1940's and 1950's.
We should note that while some think of GD&T as defining a standard for inspection of parts, that was not its intent. Rather, it was designed to communicate what the designer intended about the dimensions and tolerances of the part. Such information can be very helpful to the inspector in determine what exactly needs to be inspected to ensure the part meets the designer's original intent.
An important goal of GD&T is to ensure that a part defined using GD&T and manufactured within the proscribed limits will fit and function with the largest possible tolerances. Proper use of GD&T can add quality and reduce cost at the same time since having tolerances that are too tight can drive up costs rapidly.
When and Why Use GD&T?
Let's start in a very basic way-GD&T is designed to facilitate communication between entities that need to work together to manufacture something. If you don't have to communicate with anyone, you may not need to know GD&T. CNC Hobbyists may have little use for it, for example. But, if you are a CNC Professional, it will be extremely rare that you work on something where you don't need to communicate. Perhaps you need to make a part someone else designed. Or perhaps your part needs to fit with a part made by someone else entirely. In those cases, GD&T might save you considerable trouble. In modern CNC Shops, it becomes almost a pre-requisite that you know something about it.
Here are some of the key instances that call out for GD&T to be used:
Advantages and Disadvantages of GD&T
The advantages of GD&T are pretty straightforward:
Most GD&T devotees don't recognize many disadvantages other than that there is a learning curve you will have to get through to learn GD&T. It isn't hard, and fortunately you have already started on a free course.
Some Important Rules and Philosophy Behind GD&T
In order to be rigorous and to meet its goals, GD&T must be applied according to rules and not just willy nilly added to drawings wherever the designer wishes. GD&T does not merely add to traditional dimensions, it is a whole new way of describing the dimensions and tolerances. Here are the basic rules to be followed:
Next Article: GD&T Basic Concepts
GD&T Tutorial Home
GD&T Symbols
