Milling Machine Speeds And Feeds Calculator
Last modified: July 24, 2024
Great news! This page offers two Free Online Speeds and Feeds Calculators.
Take advantage of both HSS Feeds and Speeds with simple shop formulas and a full-featured calculator (free for a limited time) that is the industry leader, used daily by top manufacturers worldwide.
They rely on this software because it saves them time and money.
Why use the basic free calculator when you can try our full-featured G-Wizard Feeds and Speeds Calculator free for 30 days? Download it now.
It takes just 37 seconds to download and start using G-Wizard. It痴 free for 30 days and provides excellent feeds and speeds. After that, you can switch back to our free online calculator.
Take advantage of the high-performance model while it痴 free!
A photograph of an industrial milling machine.
Dark gray CNC router with flat top surface and control panel on solid gray background.
A sepia-toned image of a man sitting in front of a machine, with a workshop background and a "Beginner / Hobbyist" text box overlay.
Spindle Speed Calculator
Tool Diameter
inches
Spindle Speed:
RPM
Feed/Tooth (Chipload):
IPT (inches / tooth)
Number of Flutes (Teeth):
Feed Rate:
IPM (inches / minute)
Material
Surface Speed (SFM)
Aluminum - Wrought (6061)
250
Brass
200
Cast Iron - Ductile
90
Cast Iron - Gray
100
Copper Alloy - Wrought
120
Magnesium Alloy
250
Stainless Steel
30
Steel - Mild
110
Steel - Hard Alloy
60
Steel - Tool
60
500
Material
Surface Speed (SFM)
250
Brass
200
Cast Iron - Ductile
80
Cast Iron - Gray
120
70
Magnesium Alloy
250
Stainless Steel
30
Steel - Mild
110
Steel - Hard Alloy
60
Steel - Tool
60
Material
Chipload (IPT)
0.005 - 0.010
Brass
0.005 - 0.010
Cast Iron - Ductile
0.004 - 0.008
Cast Iron - Gray
0.002 - 0.006
0.004 - 0.008
Magnesium Alloy
0.005 - 0.010
Stainless Steel
0.002 - 0.006
Steel - Mild
0.002 - 0.010
Steel - Hard Alloy
0.002 - 0.006
Steel - Tool
0.002 - 0.006
Hang on: You Deserve Better!
Software that makes anyone a better CNC'er...  Even beginners:
A screenshot of the GWizard Machinist's Calculator tool on a machining website.
How to Calculate Material Removal Rate?
To find the highest Material Removal Rate while keeping tool life reasonable, use our G-Wizard Calculator. If you're using the free calculator, check out the Material Removal Rate Formula.
How to Calculate Feed Rate?
Need to calculate feed rate or create your own spreadsheet?
Basic feed rate formulas for milling are simple, but real-world feeds and speeds are more complex. Find all the basic formulas in our free online Feeds and Speeds Course.
