Exciting news! This page offers two Free Online Speeds and Feeds Calculators.
We provide Hss Speeds And Feeds using simple shop formulas and a full-featured, industry-leading calculator available for free (for a limited time). Trusted by thousands of top manufacturers daily.
They trust our software because it saves them time and money.
Why use the simple free calculator when you can have our full-featured G-Wizard Feeds and Speeds Calculator free for 30 days? Download it now.
It takes just 37 seconds to download and start using G-Wizard. Enjoy great feeds and speeds for 30 days at no cost. After that, you can always return to our free online calculator.
Why not take advantage of the high-performance model while it?s free?
Cnc Router Feeds And Speeds Calculator
Spindle Speed Calculator
Tool Diameter
inches
Spindle Speed:
RPM
Feed/Tooth (Chipload):
IPT (inches / tooth)
Number of Flutes (Teeth):
Feed Rate:
IPM (inches / minute)
Material
Surface Speed (SFM)
Aluminum - Wrought (6061)
250
Brass
200
Cast Iron - Ductile
90
Cast Iron - Gray
100
Copper Alloy - Wrought
120
Magnesium Alloy
250
Stainless Steel
30
Steel - Mild
110
Steel - Hard Alloy
60
Steel - Tool
60
500
Material
Surface Speed (SFM)
250
Brass
200
Cast Iron - Ductile
80
Cast Iron - Gray
120
70
Magnesium Alloy
250
Stainless Steel
30
Steel - Mild
110
Steel - Hard Alloy
60
Steel - Tool
60
Material
Chipload (IPT)
0.005 - 0.010
Brass
0.005 - 0.010
Cast Iron - Ductile
0.004 - 0.008
Cast Iron - Gray
0.002 - 0.006
0.004 - 0.008
Magnesium Alloy
0.005 - 0.010
Stainless Steel
0.002 - 0.006
Steel - Mild
0.002 - 0.010
Steel - Hard Alloy
0.002 - 0.006
Steel - Tool
0.002 - 0.006
Hang on: You Deserve Better!
Software that makes anyone a better CNC'er... Even beginners:
Milling Speeds and Feeds Calculator
Chip Load Calculator
Simple Feeds and Speeds Calculator
Tapping Feeds and Speeds Calculator
Next Feeds and Speeds Calculator
Prev Feeds and Speeds Calculator
Master Feeds and Speeds Calculator List
